Studio 2
1990
So, 8.4" discs at the front, which aren't adjustable, obviously. They've had new discs, pads, and caliper pistons + seals.
Drums at the rear, which have had new shoes, and pistons.
The car failed its MOT a few weeks ago on the imbalanced brakes, as it pulls harshly to the right under hard braking. This was before i replaced all of the components mentioned above.
The last thing on my list is to replace the master cylinder. Any other suggestions??
Cheers in advance for any help that can be offered, Paul.
Quick Braking Question
MiniLandy
, Mar 21 2010 07:22 PM
5 replies to this topic
Posted 21 March 2010 - 07:22 PM
Posted 21 March 2010 - 07:29 PM
Have you checked the brake flexi hoses as these being colapsed could course an imbalence.
Posted 21 March 2010 - 07:30 PM
Good shout!
*Grabs torch and runs outside to the mini*
Posted 21 March 2010 - 07:38 PM
Did the MOT say if it was the front or rears that were imbalanced?
Posted 21 March 2010 - 07:48 PM
It said both.
Just now discovered that the problem can't be the master cylnder, as the system is split front/rear, not left/right as i originally thought.
Urgh.
The flexi hose going to the front left, and indeed the steel brake line, seems fine. Any thoughts??
Posted 22 March 2010 - 04:03 PM
Any other possibilites at all??
Basically i've narrowed it down to being the metal brake pipe that links the front right to front right caliper, but i'm going to swap the two rubber brake pipes over first to make sure they're not having an effect.
Anything else i should be aware of??
Cheers, Paul.
Cheers, Paul.
