My Mini Has Died
19 replies to this topic
#1 chrisf
chrisf
  • 206 posts
Posted 22 March 2010 - 05:13 PM
hey guy just got towed home and pretty down now when to treat my mini lola to white paint for the roof when she died on me:( . Its an auto box and thats decide to pack up was told it seems like the pump in the gearbox had given up because it wont select a gear.
Now what are my opinions? i cant afford alot so what would be the cheap opinion i dont really want to scrap her the shel is in very good nick and i've just finished dg the inside up.
#2 Joshmini
Joshmini
    I Want To Ride My Bicycle! (Just Not Peddle)
  • 1,534 posts
Posted 22 March 2010 - 05:17 PM
Guessworks to rebuild it.
#3 chrisf
chrisf
  • 206 posts
Posted 22 March 2010 - 05:26 PM
who are they and would they take the gearbox out to i know its a engine out job?
#4 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
/ quick cheap manual conversion till you can afford the Auto 'box rebuild, if you have a manual license.
#5 Joshmini
Joshmini
  • 1,534 posts
Posted 22 March 2010 - 05:30 PM
Guessworks is his Username on here, he rebuilds gearboxes :thumbsup:
#6 chrisf
chrisf
  • 206 posts
Posted 22 March 2010 - 05:33 PM
yea manual would not be a problem but i would need a new engine and all the bits dont sound cheap???
i'll get in touch with guesswork hopefully he is close to me
#7 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 22 March 2010 - 05:35 PM
2nd vote for guessworks, he sorted me out for a very good price.
#8 chrisf
chrisf
  • 206 posts
Posted 22 March 2010 - 05:40 PM
just looked him up and says on he site he doesnt do auto gearboxes :thumbsup:
#9 rick.spi
rick.spi
  • 1,686 posts
Posted 22 March 2010 - 05:42 PM
get a manual! :thumbsup:
or you could pm mra minis and see if they do it?
#10 leaky
leaky
  • 6,890 posts
You could do a manuel 998 for not alot of money.
#11 skaterava
skaterava
  • 1,857 posts
Posted 22 March 2010 - 05:43 PM
i would convert to a manual.
#12 chrisf
chrisf
  • 206 posts
Posted 22 March 2010 - 05:52 PM
been told converting it is not to hard? just need engine gearbox new subframe? any one on here do it down south im in maidstone?
#13 Minisniper
Minisniper
  • 380 posts
  • Local Club: Market Drayton Mini Club, Minis On A Mission.
Posted 22 March 2010 - 06:51 PM
I would drop mra a PM and see what he says. Martin is very good and knows his stuff
#14 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 22 March 2010 - 09:15 PM
There are many, many threads about this on the forum. It is a reasonably simple job to convert. Easiest way is to get a whole engine/gearbox unit, as the engine block and crankshaft are different from auto to manual. It is possible to use your existing subframe, with a couple of spacer plates fitted between the engine and subframe. I believe these have to be 10mm plate, but are available from places like minispares. Dont forget though, you will also need a clutch master cylinder, a gear selector rod and clutch pedal.
#15 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 22 March 2010 - 10:59 PM
very easy to convert to manual - mine started as a 998 auto, then a 1275 manual and now a 1330 manual.
my uncle runs his own garage in maidstone and helped me do mine originally, and I live in t wells.
but i would look for a cheapish 998 to drop in, alternator starer etc should be the same; but you will need the gear selector, pedal box and master cylinder too. Na some 8mm plates seem to have secured mt engine safely.
any advice feel free to contact me :-
