Turning Down Valve Heads
6 replies to this topic
#1 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 22 March 2010 - 05:37 PM
Hi Guys
As above, is it viable to turn down valves and have the seat re-cut?
I have 29.4mm exhaust valves and they need reducing by 3mm so they do not hit the block (this is to try and save pocketing for the sake of a couple of mm)
Thanks for your help
Regards
David
#2 MRA
MRA
  • 7,607 posts
Posted 22 March 2010 - 06:48 PM
Will they still fit your head ? our valve seat inserts are 25.4mm internal diameter, your valve would have a diameter of 26.4mm so I doubt if it is going to be that easy, maybe a bespoke valve seat insert would work, or stick to a lower lift cam, as apparently this works as well :thumbsup:
#3 01smartc
01smartc
  • 1,412 posts
Posted 22 March 2010 - 08:43 PM
Yes it can be done...
We turn down 29.4mm Valves to 26mm for our Stage 3 998cc heads.
Turn the valve down then recut the seat on the valve... you will then need to re-cut the seats in the head, if its a 998 head then you can just cut the seats a little bigger.. if its a 1275 head then you can do like above and fit some 25.4mm inserts and cut them bigger.
However i would say that fitting a 1275 head then putting smaller valves in will be a bit of false econamy as it will only flow aswell as a 998 head again.. so I hope you mean your fitting bigger valves to a 998cc head
Chris @ Smart Performance
#4 nomininolife
nomininolife
  • 982 posts
Posted 22 March 2010 - 09:35 PM
Hi Guys,
Thanks for the replies.
Yes it is larger valves in a 12g295, 26mm will do the job just fine, it will be a lot better having the seats re-cut than having the block milled.
Thanks again guys
Regards
David
#5 MRA
MRA
  • 7,607 posts
Posted 22 March 2010 - 10:16 PM
I assumed that this was for a 12G940 head..... because it was to avoid pocketting the block.
The issues with turning down a valve and refacing them are ......
1) concentricity
2) correct seat angle (45 degrees)
The best tooling for this is a valve head refacing and lapping machine not normally found in a conventional machine shop :-
If this job is not performed correctly then you may find that your valves burn out quickly :thumbsup:
#6 01smartc
01smartc
  • 1,412 posts
Posted 22 March 2010 - 10:28 PM
I agree with above.. this is not a job for a balsa wood lathe from aldi
You need precision tools to put the seat back on the valve properly to ensure long life and performance
What inlet valve are you planning to use?
Chris
#7 nomininolife
nomininolife
  • 982 posts
Posted 24 March 2010 - 10:08 AM
Hi Guys
I have decided after all to just get on and pocket the block, it is the easiest way to do it, when i thought about the seat and then the valve is going to be further recessed into the head thus meaning having to reduce the length of the valve stem.
So dremel meets cylinder block!!
Its going ok so far, plenty of masking and patience lol
Thanks again guys
Regards
David
