Toggle Switches
5 replies to this topic
#1 mini420
mini420
  • 34 posts
Posted 24 March 2010 - 09:50 PM
Hello,
I am currently building a new aluminum dashboard and want to get rid of the original switches for new toggle switches. i am only keeping the headlights and hazard features. My car is a 1980 Morris with a 1293 engine and to my knowledge everything electrical is stock.
My question is how do I know what switch to replace the headlights rocker switch.
the stock switch has 1 power ans two loads coming into the switch. but im not sure what type of toggle I need.
Amop would be 20+ to be safe. but not sure on the poles or throws..... ?
Any help on this matter would really help.
Thanks in advance
Cody
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 March 2010 - 11:20 PM
The headlamp switch needs to be a single pole, three position called an off/A/A+B. The hazard switch needs to be a 4 pole double throw changeover. There is lots of information here about toggle switches if you search. I assume you have found another way to make the brake fluid warning work because it is both legally required and an important safety device.
#3 backtothemini
backtothemini
  • 17 posts
Posted 24 March 2010 - 11:44 PM
check out vehicle wiring products i managed to get all the right switches with absolutely 0 knowledge for the first mini i built, they do a very nice chrome push button that i used for break test light with a warning light attached,
but then my bro in law is an electrical engineer so i gave him a vission and he made it work lol!
#4 mini420
mini420
  • 34 posts
Posted 25 March 2010 - 02:04 AM
sorry i need to update my profile. i moved back to the US and Im no longer in Peterborough.
I dont need to have the brake fluid warning light.
Dan - thanks for the info. that is exactly what Ive been looking for. I wasnt sure on double or single pole. thank you. also for the hazard switch info. Ive been told I wouldnt find one. after looking and asking on mini mania i only searched shortly here and got nothing. thanks again.
back - having moved back to the states i got use a company a lil closer. but I already have plety in mind and have seent he wide variety of just about everything.
just didnt know the details for the switch
shouldve came to the forum first
#5 CobraV8
CobraV8
  • 991 posts
Posted 25 March 2010 - 08:13 AM
How about some on the group buy on the forum http://www.theminifo...x...=151209&hl=
I am planning on some of these for my car.
#6 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 25 March 2010 - 03:30 PM
If you're getting rid of the brake fluid tester completely then at least get a fluid tester like... >clicky<
Like dan says it's important in terms of safety. You can get them much cheaper on ebay too. Might be worth putting a hidden switch and warning light as you should have the wiring already there.
