Copper Fuel Pipe
Posted 25 March 2010 - 09:26 PM
Might sound stupid but it copper brake pipe the same as copper fuel pipe? Anything special between the two? Also (forgotten now) but where minis fitted with copper fuel pipe as standard?
Posted 25 March 2010 - 09:41 PM
Hi all,
The fuel line is a bigger diameter
Posted 25 March 2010 - 09:46 PM
Posted 25 March 2010 - 09:51 PM
But apparently it's not about the length
Posted 25 March 2010 - 09:54 PM
Posted 25 March 2010 - 09:56 PM
Brake pipe should have a 10,000psi burst pressure rating whilst your fuel line will be a lot lower..... 100psi maybe but certainly not a lot more than 100.
Also the smaller the ID the higher the pressure capacity.
Posted 25 March 2010 - 10:03 PM
Posted 25 March 2010 - 10:04 PM
Posted 28 March 2010 - 10:18 AM
5/16" (8mm) or 1/4" (6mm)?
Posted 28 March 2010 - 03:42 PM
Right, been thinking about this again, what size pipe should I run?
I'm confused on what you're using the copper for... fuel or brakes. However, based on 5/16 or 1/4 I assume you are asking about fuel line. On a street car you could use either 5/16 or 1/4. However, if you're installing everything new, consider using the larger size.
During the past week the topic of copper tubing came up on another board I frequent. In that thread a poster stated that regular copper line (plumbing copper) should never be used for fuel line because it can fatigue. I could see his argument if the line was attached to compression fittings at either end, but where the copper joins the pump and/or carb using rubber flex line I don't see fatigue as an issue. Brake lines however (as Martin said) are a different issue. Brakes line kits using copper are made from copper-nickle alloy which will have higher burst pressures and be suitable for use with compression fittings.
Posted 28 March 2010 - 04:32 PM
Edited by Pauly, 28 March 2010 - 04:32 PM.
Posted 28 March 2010 - 04:34 PM
