Can I Fit A 49d4 Electronic Ignition Kit
8 replies to this topic
#1 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 26 March 2010 - 09:49 AM
to what i presume to be a 59d distributor?
i was given a britpart electronic ignition kit (£15 new! mini specific ones are a rip-off :lol:)
and i had a quick look, and the trigger (black ring) slides over a tinyest fraction, and sort of engages on the spindle, as it you cant turn it round on the "square" part of it, but it wont go on any further, can i find a way of fitting this by shaving down the insides slightly to get it to fit?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 26 March 2010 - 10:02 AM
You question doesn't quite make sense. Are you saying the trigger ring won't fit fully onto the squared center spindle of the dizzy. If so then I've seen this mentioned before the answer seems to be to carefully trim the plastic so it does fit.
#3 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 10:14 AM
yeah lro, basically the trigger wont fit over the splindle properly, but does go on about 1mm and catches the spindle if you get me :lol:
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 26 March 2010 - 10:28 AM
This is the older version, the ring needs to go fully on, so only option is to trim the plastic. Although soaking it in boiling water may expand and soften it enough to allow you to push it on.
#5 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 10:35 AM
thanks again lro, youre quite a good source of information :lol:
is that a britpart kit too?
it has the same green bullet connector on as the one i have, but the blue sensor is now red and curves around the trigger :w00t:
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 26 March 2010 - 10:42 AM
Thats the old design from when they were only just over £6 :lol:
Got that fitted to 2 minis work a treat, no problems ..Can't vouch for the new design though not tried them.
#7 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 10:44 AM
did you have to modify the trigger to fit on yours too?
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 26 March 2010 - 10:58 AM
No :lol: and only seen people mention the problem on the new design. probably a dodgy plastic mould
#9 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 04:08 PM
success :lol:
the trigger is now on the cam, and the sensor fitted, but i couldnt finish it off because it started piddling it down :w00t:
bad times.
