How To Fit Minisport 70a Mini/metro Alternator?
4 replies to this topic
#1 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 26 March 2010 - 04:20 PM
Right, just got hold of a 70a alternator off a friend which is brand new,
the wiring plug plugs directly into the alternator BUT
there is also extra terminals on the alternator of which im not sure what they do...
there is one male lucar terminal and a threaded bolt coming off the same place which have B+ next to them, and another threaded bolt which has W next to it, and a plastic cover on the top
all i know is that on the box it has as follows: Alternator Mini/Metro 70 amp New, LRA602, and GXE2276
and on the alternator the only identification i can find is a sticker that says BBA 30/05/08, it says china on something in the middle and a circle with 'YY' in the middle on another part.
any help appreciated, ill get pictures up shortly
Edited by Carlzilla, 26 March 2010 - 04:21 PM.
#2 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 04:31 PM
pictures, as promised :lol:
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 26 March 2010 - 04:42 PM
If you've got the standard 3 way plug on your loom, just plug it in...It'll work fine.
The threaded terminal B as the same output as the two larger spade connections.
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 26 March 2010 - 04:46 PM
If you use the threaded post as your output instead if the spade plug you can make up a chunker output cable instead of the feeble standard one. Gets more power down to the starter solenoid.
#5 Carlzilla
Carlzilla
  • 1,907 posts
Posted 26 March 2010 - 04:52 PM
cheers, ill fit it now and test it, just wasnt sure of the other terminals purposes :lol:
