12 Volt Led's
5 replies to this topic
#1 scrog
scrog
  • 640 posts
Posted 27 March 2010 - 12:17 PM
help any one know where i can get some 12 volt led's from
i'm after
red green blue and orange
for a dash set up :D
#2 jacksmags
jacksmags
  • 115 posts
  • Local Club: BMC
Posted 27 March 2010 - 12:21 PM
If you want to make the circuit board yourself you can get lots of the equipment from Maplins, but you can get like premade LEDs from halfords.
Not sure these are what your after but just thought id let you know :D
#3 scrog
scrog
  • 640 posts
Posted 27 March 2010 - 12:41 PM
it's for the: high beam,indicators,ignition,neutral warnings on a bike
will give them a try cheers
#4 adam_93rio
adam_93rio
  • 3,271 posts
Posted 27 March 2010 - 01:19 PM
i think you can actually get 12V LED's from maplins, failing that try cpc
#5 mini13
mini13
  • 3,811 posts
Posted 27 March 2010 - 01:35 PM
or just buy some resistors and some heat shrink, about 1500ohms should do it.
#6 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 27 March 2010 - 01:57 PM
Have a look at my build thread. Just done some on my speedo.
Maplins is the place. 5v LED & 270 ohm resistors. They also do some 12v ones as well. Less than a quid each, resistors are pence. You can get the clips as well to fit them properly into a panel
Drop me a pm if you want the part No's I think I still have a receipt somewhere.
Regards
Steve
