Mini Mayfair Auto Performance
10 replies to this topic
#1 Brett13
Brett13
  • 63 posts
Posted 28 March 2010 - 08:38 AM
Hi ive just bought a mini mayfair auto as a project got the engine running and if im honest doesnt seem to have much pull. Im wondering what the options are ie engine tuning or would it be better to just put a manuel engine in. Going to be stating a project page soon thanks
#2 Ethel
  • 25,938 posts
Posted 28 March 2010 - 09:59 AM
There's very little difference in engine performance. Autos can be slightly better, usually higher compression etc if they're of an age when there was an option. The gearbox consumes a bit more power and the diff is often taller.
#3 MRA
MRA
  • 7,607 posts
Posted 28 March 2010 - 11:41 AM
You can tune the engine, however whatever you do make sure that you keep the bottom end torque, otherwise acceleration from rest will be worse, a stage 1 kit seems to work well ^_^
Being a Mayfair the chances are that it is already an A+ unit, one aspect often overlooked is the brakes.... are they binding on in any way ?
A good tune up will sometimes help especially if it hasn't had a tune for sometime :)
Gear tie up can also be a contributing factor, go through the gears in "D" drive then do the same using the stick to change gears try to change at the same rev point if there is a marked improvement then tie up is most likely your issue, this will need at least a valve body check :closed:
Do you get any flare from gear to gear within the auto mode, flare is when the engine revs pick up between changes, which should happen so quickly that all you hear is the revs drop as it goes in to a higher gear ratio...
#4 Brett13
Brett13
  • 63 posts
Posted 28 March 2010 - 05:28 PM
Hi ive not really had a good chance to drive the car but will do this week and check the things u said thanks. So u think keep the auto engine just a good tune and maybe a stage 1 kit. Its a 1990 mini mayfair
#5 edi57
edi57
  • 821 posts
Posted 28 March 2010 - 08:42 PM
Your engine needs very regular oil changes (every 3000 miles). If not, it really does start to affect engine performance more than you'd expect.
#6 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 28 March 2010 - 09:13 PM
What are you comparing it too?
My mate (a tmf'er) has a standard auto 1275 mayfair and it pulls well in standard form and hits a good top end (on private road of course!) I was surprised
Other mate (another tmf'er) has a 998 auto mayfair and again nowt wrong with it
As posted above, both do oil changes regularly
#7 Brett13
Brett13
  • 63 posts
Posted 29 March 2010 - 10:07 AM
Im comparing it to my 1.3 spi which i know i shouldnt
#8 MRA
MRA
  • 7,607 posts
Posted 29 March 2010 - 10:18 AM
Ouch.......... your Spi is only about 50% more powerful :)
#9 Brett13
Brett13
  • 63 posts
Posted 29 March 2010 - 10:19 AM
thats why then. Ive bought it as a project just want to get a bit more out of it really thanks
#10 MRA
MRA
  • 7,607 posts
Posted 29 March 2010 - 10:31 AM
we are working on a turbo auto :) have to see how reliable it is though :)
#11 Brett13
Brett13
  • 63 posts
Posted 29 March 2010 - 10:39 AM
Thats sounds like that could be fun :) Think i will start with a good service then a stage 1 kit n see how i go cheers
