1275 Head On A 998 Block
Posted 29 March 2010 - 11:51 AM
cheers guys
Posted 29 March 2010 - 11:59 AM
Disadvantages - takes quite a bit of work to fit. Block will required 'pockets' to be machined into the face of the block so that the exhaust valves in the 12G940 head don't impact with the block. This is really a job for a professional machine shop and will require the engine to be removed from the car. Some people have sunk the valves further into the head to avoid this issue but I've not done this.
You'll also need to modify the top edge of the water pump to avoid it fouling on the head (can be done yourself with a file/grinder if you're careful), and you'll need a new smaller size water pump pully. Then you'll need a new top radiator bracket and top hose.
Have a look/chat with Martin at MRA Minis (he's a member on the forum and has a website at mra-minis.co.uk) about his conversion gasket. It's a special gasket specifically designed for this conversion.
I have a 1062cc, with Morspeed PH3 cam and standard 12G940 on top. It's great
Posted 29 March 2010 - 01:57 PM
Posted 29 March 2010 - 02:53 PM
Posted 29 March 2010 - 04:19 PM
Posted 25 August 2016 - 04:16 PM
after much consideration, I find this quit interesting!
Posted 25 August 2016 - 10:30 PM
The car really really flies; great fun. Problems: idle is appalling and has to be set very high. Lots of times it stalls when the clutch is engaged and decelerating.
Still fun though!
Posted 25 August 2016 - 11:53 PM
Warning, zombie post, brought back from the dead!!
I built a 998 with a 12G940 head and a SW5 cam a few years back. It was a fair amount of work to build, but it was cheap and the end result was driveable, it revved out nicely, and it made 65bhp at the flywheel which exceeded my expectations. It kept up with standard 1275s OK, and it had the novelty factor of only being a 998.
Posted 03 September 2016 - 10:49 AM
sorry for bringing back an old post.. so iv looking in to this and i have a 998 block 12g940 head iv test fitted it and it work's fine the valve's clear the block but what i need to kinow is what gasket do i use?
regards mark
Posted 03 September 2016 - 12:15 PM
Phil.
Posted 03 September 2016 - 12:18 PM
thank you phil
Posted 03 September 2016 - 12:37 PM
Posted 03 September 2016 - 01:07 PM
thank you graham... ill have a look out for those
regards mark
Edited by markus82, 03 September 2016 - 04:05 PM.
Posted 05 September 2016 - 07:55 AM
Just to confirm can you YES or NO fit a 1275 head onto a 998 without any extra work?
If so on a 998 HLE 1000 can it be done and what head do I need?
Posted 05 September 2016 - 07:56 AM
Edited by JonnyAlpha, 05 September 2016 - 07:57 AM.
