I am rebuilding my wiper box (2 speed) and want to put the correct grease back into it. What is used in these? I am in the USA so hopefully we have what is needed.
Wiper Motor Grease
brivinci
, Mar 29 2010 03:48 PM
7 replies to this topic
Posted 29 March 2010 - 03:48 PM
Posted 29 March 2010 - 04:59 PM
Not sure what should be in it but I just cleaned mine up at the weekend, seemed to just have general purpose grease in the motor and I used bike chain lube for the rack
Posted 29 March 2010 - 06:14 PM
Please read the note at the top of every technical page, if a member asks for very specific information like this the answer should not start with 'I don't know but...'! Personally I wouldn't use chain oil for this application, it's too sticky really. The point is to reduce the load on the motor not increase it!
The real stuff is called Ragosine Listate grease. It's a product of a very old British refinery called the Ragosine Oil Company Ltd, now ROCOL. You won't find it anywhere, Google it and see how many of the responses bring you back here! Rocol greases are now called Saphire and they don't list one as being a direct replacement, I suspect that even Lucas have started using a general purpose lithium grease as a replacement. If you do happen to find any Listate grease over there, or a product listed as compatible with it, ship some to me!
Posted 29 March 2010 - 07:44 PM
I used this stuff
http://www.onlinebea...y-pr-16317.html
works a treat. good for the door locks as well.
Posted 29 March 2010 - 09:14 PM
Thanks a lot.
I will do my best to search for that product. On that Sapphire spray, is that good for the motor box or just the rack? Do you use the same oil/grease for both?
Posted 30 March 2010 - 06:45 PM
Also, I was told that 30w oil for the bushings and then coating the rest (gears and such) with a nice coating of Vaseline work very well.
Posted 04 April 2010 - 07:09 PM
I'm about to re-grease my wiper rack.
I have been thinking of using a general purpose grease (Castrol LM) but keep thinking that it's just a little too viscous.
I have a couple of sachets of CV joint grease.. I know that that is a bit less viscous.
Any thoughts for or against this idea?
Ed
Ed
Edited by edi57, 04 April 2010 - 07:10 PM.
Posted 04 April 2010 - 07:34 PM
the place i used to work did re-conditioning of wiper box's, a fully mechanicle thing and was built with some sort of red lube which was bought from halfords, i think it was a cycle lube though.
