Lcb Question
steble
, Mar 29 2010 05:01 PM
10 replies to this topic
Posted 29 March 2010 - 05:01 PM
a friend of mine wants a lcb manifold i have in the shed. but his car is an spi so it will have a lambda sensor i guess. my lcb is a carb one so won't have this can you just drill a hole and tap it?
Posted 29 March 2010 - 05:12 PM
the lambda are threaded so the screw into the lcb
Posted 29 March 2010 - 05:14 PM
He knows this,hes asking if he can create a thread in the lcb for the sensor to screw into
Posted 29 March 2010 - 05:15 PM
you can buy the bosses, not sure where from
Posted 29 March 2010 - 05:18 PM
I cant see why not,although im sure a clever clogs will be along to say otherwise.
I would mount the sensor at the bottom so you get a reading from all the pipes,then extend the wiring for the sensor.
Posted 29 March 2010 - 05:21 PM
Edit,i had a carb LCB sent for my injection cooper by mistake,and the center pipe was totally different to the injection pipe,so even if you tap a hole im unsure if the center pipe will be any good
Posted 29 March 2010 - 06:33 PM
Im not sure but the lambda sensor on injection LCB's have to be in a curtain place on the pipe so the sensor can take accurate readings, I think I read where curtain LCB's where making injection cars run poorly due to the posistion of the sensors, if you was just running an AFR gauge then you would mount it where you like, but when the ECU relies on it for the correct running of the engine then its more critical.
If it was me I would keep the standard manifold, its a lot better than you think (one of the best manifolds rover made I beleive) I think they are good for up to 100hp!
Edited by Pauly, 29 March 2010 - 06:34 PM.
Posted 29 March 2010 - 06:57 PM
The ECU only takes a reading from two pipes on the majority of LCBs, LCBs are available with the sensor mounted where the three pipes converge , thus enabling a " true " reading from the exhaust gas.This type is often supplied with an extension to the existing Lambda wiring.
Posted 29 March 2010 - 10:44 PM
so basically my carb lcb manifold is useless to him then
oh well i keep telling him to man up and get a carb lol
Posted 29 March 2010 - 11:04 PM
think demon tweeks do a kit just need to drill and weld the manifold or you could sell it to me?
Posted 30 March 2010 - 09:53 AM
your welcome to it if you want it mate
