I have read a few things about it but they are all from the seller's point of view and i was hopping one of you guys have done this and recomend it??
cheers biggles
Posted 29 March 2010 - 09:43 PM
Posted 29 March 2010 - 10:08 PM
Posted 29 March 2010 - 10:22 PM
Posted 29 March 2010 - 10:33 PM
Posted 29 March 2010 - 10:36 PM
i think you wld only get a few horses in doing this. you could still rin the fan pulley to keep the same belt just without the fan.. its alot of trouble to go to for the sake of max 5hp??
Posted 29 March 2010 - 10:40 PM
Posted 29 March 2010 - 11:12 PM
what taking the mechanical one off and fitting an electrical one?? i dnt know personally.. i wld have thought the mechanical one is just as good. if you just wanted added colling just add a suction fan on the outside of the inner wing.
Posted 29 March 2010 - 11:13 PM
Posted 29 March 2010 - 11:17 PM
well they are all saying it improve's your economy and performance because there is less dragg on the flywheel and the cooling is improved and this cause's your motor to run better, im having a small cooling problem anyways it seams to want to overheat when im sat in traffic or idleing for a long period of time due to the lack of fan power basicly, so im gunna get it and fit the beast this week hopefully.
Ill report back and let you guys know if ya want?
cheers, biggles
Posted 29 March 2010 - 11:36 PM
Posted 29 March 2010 - 11:39 PM
if its just the problem with cooling your having then fit an electric fan to the inner wing, this will sort any overheating problems out
but i wouldnt bother getting rid of the mechanical fan
