Carb Icing On A Vmax Setup
Posted 31 March 2010 - 11:10 AM
I was thinking perhaps close off the section behind the grill infront of the carb with sheet alloy ?
Also is there a way to duct hot air from the exhaust LCB ?
Neil.
Posted 31 March 2010 - 05:27 PM
Posted 31 March 2010 - 06:50 PM
Apart from fitting a heater has anyone done any other mods to cure carb icing on a vmax SC setup?
Neil.
Yeh, do it properly with a blow though setup.
Posted 31 March 2010 - 07:14 PM
look at thread "diy superchager" (it runs) got the part Number on there.
joe
Posted 31 March 2010 - 07:19 PM
Posted 01 April 2010 - 12:43 PM
Posted 01 April 2010 - 09:15 PM
but I was also thinking at the moment I have no front grill so loads of cold air when driving if I blanked it off with sheet alloy it might raise the temp in the engine bay ???
Neil.
Posted 02 April 2010 - 04:18 AM
I looked at the vmax scart option but didn't fancy the £100 price tag and opted for the free water heated K'N! I mabe a a coil to fit inside the filter (not an easy fit, you can only fit 2 turns in the bottom and 1 in the top, forming a figure o' eight inside the filter)
Add a couple of pipe reduces and plumbed it in to my heater line ( i have no heater so you would need to T off it if you have), open heater valve and hot water circulates through the filter and back to the bottom hose. Going to add some coils to the intake pipe on the Mk2 version. This fixed the carb icing nicely.
Edited by chinner, 02 April 2010 - 04:21 AM.
Posted 02 April 2010 - 12:01 PM
has anybody used webers on a supercharged setup? (sorry bit off topic)
Posted 03 April 2010 - 02:03 PM
Looks like microbore heating pipe does it restrict flow to heater?
N.
Posted 03 April 2010 - 02:59 PM
Posted 03 April 2010 - 06:36 PM
dave
Posted 03 April 2010 - 08:40 PM
that idea above is amazing! i will have to look into this when fitting downdraft webers.
i thought up this idea years ago....
no real need for weber's , as the charger setup's dont make the power or fuel demand to warrent this.....
Posted 03 April 2010 - 08:41 PM
physics comes to mind and power loss, fuel traveling through air is going to freeze, warm up the air and lose power. you dont want suck through you want blow through, and remember supercharge life is approx 15-20k when passing fuel through it compared to 80,000-100,000 when it only has air passing.
dave
same as not being able to use diesel turbo's on petrol engine's.....
Posted 04 April 2010 - 12:01 AM
