Electrical Problem
Posted 01 April 2010 - 03:25 PM
Posted 01 April 2010 - 03:39 PM
Posted 03 April 2010 - 04:48 PM
Posted 03 April 2010 - 05:47 PM
I have a big problem with my 1998 mini rover mpi. I repainted it and put the engine back in. It turns on fine and all the harness wire is plugged in except one that is (Black /Black green). I don’t know where it goes.
Please indicate where the plug is located near, to give us a clue. Also, a photo?
Is the plug a multiplug connector, or is it a normalspade plug etc? is it two wires on the same plug - black AND black with green? are you sure it is not green with black? is the green light green or dark?
Bit more info required for confirmation
Ryan
Posted 05 April 2010 - 10:59 PM
Posted 05 April 2010 - 11:04 PM
Posted 06 April 2010 - 06:12 AM
black AND black with green....is the plug on the left..the plug on the right is for the horn the two plug or run together...
I think the black and black/green plug supplies power to the cooling fan - have you connected a plug to it yet?
Posted 06 April 2010 - 02:43 PM
Posted 07 April 2010 - 07:58 PM
Posted 09 April 2010 - 04:17 PM
Posted 09 April 2010 - 06:06 PM
i was checking a engine management book and it said that the (black/black green) is for the oxygen sensor is that true and if so were is it....
Yes, there is a black with green wire that goes from the ECU plug to the Mems relay box which is mounted on top of the brake servo. The oxygen sensor( lamda sensor) is screwed into the exhaust manifold. The plug you show in the photo is definately not to do with the lamda stuff.
Posted 17 April 2010 - 02:20 AM
Posted 22 April 2010 - 08:42 PM
1999 1.3 mpi
I was considering hijacking this post as i have a similar problem. If i put the side lights on everything is ok i can use signals wipers etc. If i put the headlights on the nearside headlight comes on dim and the offside one stays off. When the headlights are on the wipers don't work the stereo goes off and the signals don't work very strange!! I have traced it to the earth header under the expansion tank. It is a multiple spade connector and moving the wires caused the fault to go and come back all the earths for lights wipers etc go back to this point. i think I'm gunner cut it off and put some eyelets on a bolt instead.
Hope this helps with the strange faults on mpi lights
Chris
