Year:1994
changing to center binnacle. all wirings are ok except ignition switch light and oil pressure light. yes, i have read and search old topics and tried them out but still nothing. the bulbs are ok.
ignition light - 12v taken from white wire (live) connects to red from the bulb and then earth to the brown yellow.
oil pressure light - 12v taken from white (live) connects to red from the bulb and then earth to white brown
is this right?
found from the guide that he doesnt do this but still can get the lights up. what he did was earth (black) to earth from the instrument loom then matches up all the other wirings to the loom absed on their respective colour codes.
did that but still no lights up...
help needed.
another thing, how to convert the igistion switch to an older model one (mk1) with only 3 inputs. the standard has 4 inputs batt (brown), auxillary (light green white), ignition (white) and crank (brown red). no problem to connect the batt (no 1 from the ignition switch back) and crank (no 3 from the ignition switch back), but nothing happens when connecting the aux and ignition (to no 2 from the back of the ignition switch).
how to do up the wiring so that aux and ignition can be operated..
Edited by jaaroquai, 02 April 2010 - 10:20 AM.
