Having Problems Fitting Rear Neg Camber Brackets
5 replies to this topic
#1 fergy
fergy
  • 224 posts
Posted 09 April 2010 - 03:35 PM
the brackets are cathching on the subframe mounting points has any one else had this problem and does anyone no how to fix it?
#2 jonny d
jonny d
  • 1,148 posts
Posted 09 April 2010 - 05:07 PM
who's make of brackets are they because I had the same trouble with minisport camber and toe brackets, phoned them up and they told me to grind them with a grinder at an angle till they just fit said they are going to put it on there instructions
#3 fergy
fergy
  • 224 posts
Posted 09 April 2010 - 07:43 PM
yeh mine are minisport i took a file to them earlyer this evening and got them fitting now thanks.
#4 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 09 April 2010 - 08:01 PM
Got mine from min it's last week, bolt alignment was all over the place, having done a slack bolt individual tighten up it seems to pull itself into shape, but they're very bent compared to how they arrived, that can't be right ??
#5 fergy
fergy
  • 224 posts
Posted 09 April 2010 - 08:05 PM
i have heard of peolpe elongating the holes
#6 sketch131313
sketch131313
  • 21 posts
Posted 10 April 2010 - 10:02 AM
Recently fitted some from Mini Spares.
Bit awkward to fit but involved lining up top 2 holes and fitting bolts very loosely then using wiggling and a bit of brute force with a mallet to get rest of holes lined up.
Once in just tighten up, you shouldnt have to elongate the holes of the bracket as the main point of the bracket is to keep the angles correct once fitted.
