Lost 3rd And 4th, Any Ideas?
2 replies to this topic
#1 Timmy Clubman
Timmy Clubman
  • 116 posts
  • Local Club: I've never seen the point
Posted 09 April 2010 - 09:23 PM
Well, basicaly what happend was - i drove about 5 miles from my house on normal roads then about 30 on the motorway.
I turned into an industrial estate, went down to second but when i went to change up into third there was no drive so i went into fourth.
Tried third again, nothing, back into fourth and there was no drive there either
Do any of you have any ideas what it could be?
(The gearbox has been whining like mad ever since the day i got it about 6 months ago, could it be the bearings? one of them finaly gone
enough for something to not line up)
Any help greatly apreciated as im back at work monday so wont be able to do much about it after that (exept get a new car :P )
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 April 2010 - 10:23 PM
No 3rd or 4th sounds like a selector issue...
If you loose 4th gear ( ie no teath ) you loose all gears, so as you still have 1st & 2nd it suggests that either the synchro hub for 3rd/4th has let go or there's something not allowing you to select the gears..
Only problem is, it's engine out time...
#3 Timmy Clubman
Timmy Clubman
  • 116 posts
Posted 10 April 2010 - 07:23 AM
Oh no engine out time :P
Thanks guess works
