Hi Wondering if anyone can tell me what needs to be fitted to the crank to have it dynamicly balanced is it just the flywheel and the dynamic damper or do you also have to fit the preassure plate, clutchplate, clutch cover and timing chain cog.
Many thanks
Dynamic Crank Balancing
alunevansodp
, Apr 10 2010 11:54 AM
1 reply to this topic
Posted 10 April 2010 - 11:54 AM
Posted 10 April 2010 - 12:47 PM
In theory all the rotating assembly. some bits aren't practical because you're not likely to reassemble then to a close enough tolerance to make a difference. Flywheel, crank & damper should do. The clutch plate rotates with the gearbox.
Many thanks
