How To Keep Sump Washer Central?
15 replies to this topic
#1 AlexP
AlexP
  • 230 posts
Posted 11 April 2010 - 11:55 AM
Any tips on how to keep the sump wash perfectly central when tightening it up? I always seem to end up with an off-centre washer and an oil leak!
#2 adam_93rio
adam_93rio
  • 3,271 posts
Posted 11 April 2010 - 12:08 PM
cant you get a different sized washer? one that sits more tightly on the sump plug itself?
this way it wouldnt be able to go off centre when tightening up
or stick some sealant round it
#3 mars red mike
mars red mike
  • 1,500 posts
Posted 11 April 2010 - 12:32 PM
I use a very thin smear of grease on the one side of the washer, just enough to hold it in place. I have been doing it like this for years and it has never leaked yet.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 11 April 2010 - 12:42 PM
a spot of super glue .......this will hold it in place and once you've titghtened it up .....job done.......... :)
#5 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 11 April 2010 - 01:20 PM
Your leak could be because the washer has become work hardened. If you have used the same copper washer more than a coulpe if times you will find it starts to get very hard and wont seal too well. You can soften it again by annealing, just heat the washer over a gas cooker until it is red hot and then let it cool and you will find it is soft once again.
Matey boy explains the process here -
Edited by pogie, 11 April 2010 - 01:21 PM.
#6 AlexP
AlexP
  • 230 posts
Posted 11 April 2010 - 01:33 PM
I always use a new washer as they are cheap as chips (from shows) and I see no point in using an old one.
I need a large (the standard) washer due to the helicoil, a small washer has a bit of a problem.
I like the grease idea - think that'd what i'll try next!
#7 MRA
MRA
  • 7,607 posts
Posted 11 April 2010 - 01:42 PM
Either the sump plug or copper washer are not the correct size :thumbsup:
#8 AlexP
AlexP
  • 230 posts
Posted 11 April 2010 - 01:45 PM
hmm, I always thought that the washer was a loose fit over the plug? All the one's have a bought from Minispares and from shows are the same. This has been the case on 2 different minis too.
What washers do you use then Mr. MRA?
#9 MRA
MRA
  • 7,607 posts
Posted 11 April 2010 - 02:00 PM
We manufacture sump plugs that work with the current copper washers available or we use a special rubber seal inserted washer which is designed to fit the 5/8" diameter of the sump plug.
The cheaper replacement sump plugs, have a massive undercut which is not good for the copper washer.
#10 AlexP
AlexP
  • 230 posts
Posted 11 April 2010 - 04:26 PM
Might have to pick up one of your plugs then!
Will they fit a helicoiled gearbox? I assume it will (as far as I can tell the current plug is a std 5/8" one).
#11 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 11 April 2010 - 04:33 PM
I use THESE
Never had a leak yet. (not from the sump plug anyways :thumbsup:)
#12 MRA
MRA
  • 7,607 posts
Posted 12 April 2010 - 10:00 AM
Dowty washers are also very good :thumbsup:
And yes sump plugs are 5/8" thread and will work with a helicoil fitted.
#13 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 April 2010 - 01:32 PM
I use THESE
Never had a leak yet. (not from the sump plug anyways :dontgetit:)
Great link, I used to get them from Halfords until the miserable bleeders stopped stocking them.
I believe they were classed as Ford Mondeo sump plug washers, but they also worked a treat on the Mini.
#14 AlexP
AlexP
  • 230 posts
Posted 12 April 2010 - 01:35 PM
I bought the 'Mondeo' washer only a week ago from halfords!
Still leaks though. I think the helicoil messes with the small diameter bonded area.
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 12 April 2010 - 01:38 PM
Mines been heli-coiled and it was always fine with that type of washer. In fact the garage who fitted the heli-coil recommended using them.
I've got a standard type copper washer there at the moment and I think it does leak a tiny bit.
As for Halfords, well no doubt my local branch (which is useless) were telling porkies then.
