Mg Zr Seats In A Mini
9 replies to this topic
#1 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 11 April 2010 - 03:07 PM
Hi all
I have just picked up a set of MG ZR seats form a 2004 car.
I have just trial fitted them into the car, and they fit... well not really. I need to find some way of attaching them to the car.
Looks like the runners are built into the frame of the seat. I can make up custom brackets but wondered if someone had done this before me
MIke
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 April 2010 - 03:39 PM
ive got a set of half leather ones for mine. Havent looked at them yet, but expect to make custom brackets.
Let me know how you get on.
#3 JamesGodfrey1992
JamesGodfrey1992
  • 422 posts
Posted 11 April 2010 - 05:09 PM
mines are practically mg zr seats.
we modified the brackets on the front seats to make them work on there on runners, and took the covers of the rear ones then cut the foam to the correct shape which allowed to have a snug fit then recovered them again :thumbsup:
hope this helped. :teehee:
#4 mykweb
mykweb
  • 543 posts
Posted 11 April 2010 - 09:10 PM
Cool man cheers for that
do you have any pictures of how you attached the front seats to the car?
Mike
#5 minimalal
minimalal
  • 222 posts
  • Local Club: Eastbourne
Posted 11 April 2010 - 09:27 PM
yes they fit, my best friend has mg zr seats, i believe he used the original runners and made custom brackets like you said.
i will say though they are very snug fit, accesibility too the handbrake is very limited and you do sit quite high just incase your tall haha hope this helps!
#6 mykweb
mykweb
  • 543 posts
Posted 12 April 2010 - 07:06 PM
does ur mate have any pictures you can post of the brackets.
I have bought some metal and box section I am going to attempt it tomorrow but just looking for inspiration
Mike
#7 minimalal
minimalal
  • 222 posts
Posted 12 April 2010 - 09:16 PM
ill give him a ring tommorow and pop over with my camera too try and get some for ya mate. im rather interested in how he did it himself aswell haha
#8 diamondd
diamondd
  • 19 posts
Posted 13 April 2010 - 06:47 AM
I put the MGZR seats in my mini, they're not too bad to fit. First, you have to drill out all the old brackets on the bottom of the seat so you are left with smooth runners. The I got 2 pieces of aluminium stock, one is 3 inch by 3 inch angle and 3 inch by 1.5 inch box. The 3x3 angle bolts to the front of the runners in the old bracket holes and it overlaps the front of the box section in the car where the original seat mounted. In the back of the seat I used the 3x1.5 box as a support for the seat to sit on. It's bolted to the bottom of the runners as well but it just sits on the carpet, you could bolt that to the floor if you wanted.
#9 Youngowner93
Youngowner93
  • 426 posts
  • Local Club: Durham Mini Club
Posted 09 March 2011 - 05:25 PM
I'll get some pictures of my frames up later :)
#10 Youngowner93
Youngowner93
  • 426 posts
Posted 10 March 2011 - 09:44 AM
As promised here are my frames:
All i did was weld a couple of pieces of thick flat bar together to form a square. I then made the back support of the same stuff and made some mounts for the front to bolt to using the original Mini seat mounts. I drilled a couple of holes and bolted the seat runners to the frame. :dontgetit:
