Manifold Change
5 replies to this topic
#1 jemo
jemo
  • 38 posts
Posted 12 April 2010 - 09:53 PM
Hi, Can someone tell me what is involved in changing the exhaust manifold on an MPi? There is an lcb fitted that I would like to swap out - can this be done without taking the head off to make room and if so can it be done largely from above or do you need to feed it in from below which would imply a high lift ramp is required?
Thanks!
#2 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 12 April 2010 - 10:00 PM
best taking from underneath, i would take off top engine steady so you have bit of leaverage of the block so you can get your hands in there..
as said easier to take from under the car i would say anyway, bit fiddly tho
Edited by cooperdan, 12 April 2010 - 10:02 PM.
#3 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 13 April 2010 - 04:22 PM
If it is an LCB, then the "Y" branch will most likely have to come out the top.
Terry
#4 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 18 April 2010 - 10:19 AM
Easy job and can be done innthe hour with some swearing involved.
Secure car
disconnect fuel lines from left of engine bay.
Disconnect all wire harness going to inlet manifold
disconnect throttle cable
disconnect vacume hose for brake
undo the 5 1/2 inch bolts holding the inlet and the manifold on.
Remove the inlet manifold and make sure you save/ retreive the alloy collars from the head or inlet manifold.
Jack up front of car.
Remove the bolts from the cat
if you have the standard manifold on the car you will need a long wobble bar with a 1/2 inch socket. If it's a aftermarket lcb. You will need to remove the Y piece. You may need to cut/chisel this off
then fitting is the reverse
make sure you replace the exhaust gasket
#5 jemo
jemo
  • 38 posts
Posted 20 April 2010 - 08:03 PM
Folks,
Many thanks for your replies. Good to know it can be done and you make it sound so easy mykweb :blink:
Secure car
#6 mykweb
mykweb
  • 543 posts
Posted 22 April 2010 - 12:18 PM
Folks,
Many thanks for your replies. Good to know it can be done and you make it sound so easy mykweb :)
Secure car
Done this a few times now :(
where are you based?
