Weak Brakes
Posted 13 April 2010 - 10:07 AM
Posted 13 April 2010 - 10:10 AM
hi all, im having a bit of a problem with my minis front drum brakes. first of all the pedal travels almost all the way to the floor before i get anykind of braking power and when it does start braking it pulls to the right quite violently. i think ive adjusted all the shoes properly, ive put new fluid in and bled it through change some brake lines, all the brake cyclinders seem ok but still having problems? any ideas. many thanks Jacques
The pulling to the right sounds like poor brake performance on the left hand side of the car.
Is this a new thing --> the whole poor braking I mean?
Posted 13 April 2010 - 10:13 AM
ty for reply, the brakes have always been poor and pulled to one side so i decided to have a look and adjusted the brakes shoes so that there was just a bit of friction between them and the drum but it did not make a difference, so i changed some brake lines and used new fluid but nothing.
Posted 13 April 2010 - 10:15 AM
Posted 13 April 2010 - 10:24 AM
Posted 13 April 2010 - 12:00 PM
in a normal mini is the pedal meant to travel very far down?
Did you bleed them in the order and manner as per Haynes?
Posted 13 April 2010 - 02:43 PM
