No Lights Or Horn
6 replies to this topic
#1 lee60acv
lee60acv
  • 17 posts
Posted 14 April 2010 - 10:00 PM
just fitted a metro mg engine and got it all running spot on but then relized i had no lights or horn working. I have checked the fuse its fine and the only wires i have allterd is the starter motor ones as changed it to run a pre engaged starter any one got any ideas
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 April 2010 - 10:11 PM
What Mini is it? Please answer the questions the new thread form asked, not all Minis are the same.
#3 lee60acv
lee60acv
  • 17 posts
Posted 14 April 2010 - 10:13 PM
Its a mini 25 1984
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 April 2010 - 10:18 PM
The lighting and fuses 3 and 4 are all supplied through the second spade connector at the solenoid I believe, have you connected that properly?
#5 lee60acv
lee60acv
  • 17 posts
Posted 14 April 2010 - 10:24 PM
Im not 100% sure i put all the wires on to 1 side of the old solenoid to save extending them all and had to just change a couple of the wires around to make it run
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 April 2010 - 10:26 PM
Well there should be 4 fairly thick brown and possibly brown/blue cables coming from the loom which all need to run to the battery supply terminal together.
#7 lee60acv
lee60acv
  • 17 posts
Posted 14 April 2010 - 10:28 PM
ok mate il check that out tomorow thanks
