Oil Temp Sensor Location
2 replies to this topic
#1 philly c
philly c
  • 316 posts
Posted 15 April 2010 - 06:36 PM
hey peeps
Please correct me if i am wrong but....
If i unscrew the original oil pressure sender i can then drill an re tap it to accept a hose which connects to the pressure sender provided. the only other question i am confused about is where the oil temp sensor screws into??
Can you help??
many thanks
phil
#2 wtverouden
wtverouden
  • 76 posts
Posted 15 April 2010 - 10:03 PM
hi phil,
take the sump off, drill a hole, weld a threaded bush on it where the temp sensor goes in.
cheers.
pim
#3 philly c
philly c
  • 316 posts
Posted 16 April 2010 - 06:13 AM
cheers Pim
i dont suppose you have any pictures of what you did you yours have you as i think i may find this a little easy just to grasp it all ;
Many Thanks
