Which Way To Mount My Subs. Upside Down Or Normaly
8 replies to this topic
#1 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 15 April 2010 - 08:05 PM
i have 3 8 inch subs and am just wondering if mounting 2 upside down ie been mounted from under neith my shelf and one mounting from the top will have any bad points in the bass produced?
thanks for your help in advance hawxie :thumbsup:
#2 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 15 April 2010 - 09:06 PM
have them pointing forward just behind the gap between the front seats :D
#3 carts60
carts60
  • 1,007 posts
Posted 15 April 2010 - 09:08 PM
My head is telling me that (im assuming the subs are sharing the same air space) having them facing different directions could be bad.
The pressure of them all driving in the same direction would be fine as they are all doing exactly the same thing, but turning one around would mean its driving against the other two.
I'v got a feeling it could cancel bass due to constructive and destructive sound waves. It might also harm the subs too.
This is all just speculation from me though. I'm sure someobody will come in with the real nitty gritty behind why its kosher or not
#4 h4wx1e
h4wx1e
  • 553 posts
Posted 15 April 2010 - 09:12 PM
actually i could even remake the rear seat and mount them down the middle of the rear bulk head :D and have the magnets facing inside the car because they are chrome :D
#5 h4wx1e
h4wx1e
  • 553 posts
Posted 15 April 2010 - 09:16 PM
cheers for the advice, i think you are probably right its just the clearence issue i have with the petrol tank thats why i thought about putting two magnet side up at either end and mounting one normally in the middle of the parcel shelf
#6 pbrain
pbrain
  • 431 posts
  • Local Club: not yet
Posted 16 April 2010 - 07:52 AM
you can have 2 subs facing down & a sub facing up with no problems. all you need to do is reverse the wiring to the upside down subs to the upright ones, this will keep them in phase. Mixing in & out like this is quite common in multi-sub arrays. Some professional PA companies make their sub-boxes like this, they believe it reduces distortion.
Another reason to point the subs down is that it increases the volume of the box, some people do it if their sub looks better from behind!
#7 h4wx1e
h4wx1e
  • 553 posts
Posted 16 April 2010 - 10:09 AM
sorry mate but i dont understand what you mean with regards to wiring? im running a vibe mono amp if that helps?
Edited by h4wx1e, 16 April 2010 - 10:10 AM.
#8 Rich.
Rich.
  • 520 posts
Posted 16 April 2010 - 10:43 AM
Your speakers have a phase. So, remeber each speaker you have is basically an electromagnet, when possitive is applied it moves to say fully extended. So, if you have speakers facing the opposite ways, and wired in the same way, so possitive to positive on every speaker, due to them facing opposite directions, when possitive is applied to every speaker, two are going to move in one direction and one in the opposite, because its facing the opposite way to the others. To combat this you need to reverse the poitive and negative on the speaker thats facing the other way round, so your possitive from the amp will go to the negative marked terminal on the driver.
Rich
#9 h4wx1e
h4wx1e
  • 553 posts
Posted 16 April 2010 - 10:47 AM
thanks alot for the info gents muchly apreciated. looks like i can get on with it now. thanks again hawxie :D
