Swivel Joint Stuck In Upper Suspension Arm
Posted 18 April 2010 - 06:05 PM
Year:1991
Hi
I'm on my way to getting my engine out but I can't get one of the swivel joint bolts out from the upper suspension arm. I've removed the nut but no method I can think of will budge the bolt from the swivel joint. I've used two different types of universal joint seperators - the one with the bolt on bolt action is rubbish because the bolts slip off and the more scissor looking type stayed in place but it was so stuck I gave in before the joint did. I've applied plenty of penetrating oil over days and days, applied heat and everything from gentle taps to whacks with hammers. It must be rusted solid, but I've never come across anything which is so stubborn...especially so close to getting the engine out.
This is my first post so please forgive me if I've done it all wrong.
Any help would be great!
Pete
Posted 18 April 2010 - 06:07 PM
Posted 18 April 2010 - 06:08 PM
Posted 18 April 2010 - 06:10 PM
Posted 18 April 2010 - 07:06 PM
yo should always leave the nut on at least 2 thirds of the way, to prevent you from fubburring the thread up.
Edited by samsernie, 18 April 2010 - 07:09 PM.
Posted 18 April 2010 - 07:56 PM
Posted 18 April 2010 - 08:11 PM
Edited by samsernie, 18 April 2010 - 08:13 PM.
Posted 19 April 2010 - 09:08 AM
Then i remembered.. my drill
Posted 19 April 2010 - 10:11 AM
Posted 19 April 2010 - 11:00 AM
I work on the car at weekends as it lives at my parents house at the moment. I will try all of the above suggestions. Unfortunately whilst using the bolt on bolt separator unsuccessfully a few too many times I ruined the thread on the top of the bolt and can't get the nut back on. Using it to align the bolts was a great idea!- why didn't I try that!? Then thinking all was probably lost I went with the last resort of using a mole grip, which didn't work and destroyed the thread completely.
I had the suspension arm pretty level and tried releasing the bolt at all sorts of angles
I was wondering if dismantling the ball joint whilst still attached would help at all so I was just left with the bolt in the arm without the hub/brake in the way? - does anyone know the size spanner to get around the ball joint? The biggest one I own is 1" and its a bit bigger than that - I could buy one then ready for my next trip to fix the mini
Pete
Edited by greenmini, 19 April 2010 - 11:02 AM.
Posted 19 April 2010 - 11:11 AM
On mine it took a lot of effort to break the taper but applying lots of heat is the answer - tighten up the ball joint separator, heat the suspension arm then hit the end with a hammer.
Posted 19 April 2010 - 11:14 AM
Posted 19 April 2010 - 11:26 AM
Posted 19 April 2010 - 11:35 AM
What heat have you used? I'd put a blowtorch and heat up the ring end on the top arm for a few minutes, even leave the ball joint splitter fitted and under tension whilst heating it up.
Is this all just to get the engine out? You could always just cut the strap holding on the inboard CV gaitor and wiggle the drive shaft out of the pot joint this way...
Posted 19 April 2010 - 12:21 PM
My preference is to use a scissor type splitter. Tighten it up as much as you can then strike the side of the arm next to where the bj goes through with a good heavy hammer. Ideally hold another hammer on the opposite side of the arm at the same time as you'll get a more solid hit.
