Spraying The Roof
11 replies to this topic
#1 lrostoke
lrostoke
  • 6,923 posts
Posted 24 April 2010 - 08:18 PM
Any tips on spraying the roof, its a pretty big area and I seem to find that you obviously can't reach all the way across, so keeping a wet edge going seems difficult .
You start on one side and get round to the other you are then getting over spray on the shiney bits.
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 24 April 2010 - 09:05 PM
Panelbeaterpeter did a sketch about this a while ago.
His technique was to paint the front left 1/2 and then the front right 1/2 followed by the rear left 1/2 and then finally the rear right 1/2.
I've never tried this, but cannot doubt him(ps left me know if it works for you!!)
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 24 April 2010 - 09:11 PM
Sounds like a plan :D
Its either that or tip it on an angle :P
#4 Senile Old Git
Senile Old Git
  • 2,409 posts
  • Local Club: Rutland Minis
Posted 25 April 2010 - 12:01 PM
Spray around the gutter first.
Then spray left to right or right to left ( depends if you a kak handed) from the side above the side windows, once you have got to the middle run around to the otherside and start from where you left off. This prevents the paint "drying" in the middle and allows time for the paint to "flow" out
#5 akaflash
akaflash
  • 96 posts
Posted 25 April 2010 - 12:10 PM
use a slow thinner then paint stays wetter longer
#6 Scallywag630
Scallywag630
  • 2,850 posts
Posted 25 April 2010 - 12:12 PM
Or you could rig up a harness and suspend yourself from the ceiling.....lol
#7 Senile Old Git
Senile Old Git
  • 2,409 posts
Posted 25 April 2010 - 12:50 PM
Have you been for early doors ?
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 25 April 2010 - 02:40 PM
Mission Impossible Tom Cruise style :shifty: that was mentioned ha ha
#9 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 25 April 2010 - 06:28 PM
I'm not sure what I was on when I posted that, for a big area that's the best way, and I guess if you're not too confident it would still work, but you can quite easily paint the roof without getting dry areas by painting from the outside in, then go round and carry on from the middle to the outside. Always do the gutters first, but only do inside them once, or you'll get run around the edge as it'll build up and cause runs. I can reach about three quarters across the roof from standing on one side, I am quite tall, but there's no reason why you couldn't do the same if you stood on something. Shifty's shoulders, maybe.
Edited by panelbeaterpeter, 25 April 2010 - 06:28 PM.
#10 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 25 April 2010 - 06:31 PM
I'm sure you'd need something a bit bigger than me!!
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 25 April 2010 - 07:35 PM
Well I'm 6ft, bro in law is probably 5'7 so think we can get away with that :shifty:
#12 mick black
mick black
  • 35 posts
  • Local Club: northwest mini club
Posted 25 April 2010 - 08:09 PM
i must have read it wrong did you mean slow activator caus the thinners is standard thinners
