My 1275 A+ block is at the machine shop waiting for a re-bore. Apparently it's border line if a plus 20 thou bore will be OK so I'll probably ask for a plus 40 thou re-bore. I need to buy a new set of pistons and get them to the machine shop to have them measured before final honing of the block, hence my choice to go 40 thou rather than buying a set of 20 thou pistons and finding that the bores are no good at 20 thou.
Now, to work out the compression ratio I need fit the pistons in the block, but I don't know which pistons to buy because the piston obviously affects the compression ratio, and to work out the compression ratio I need to trial fit the piston.
Engine is an early 1275 MG Metro. I have a later un-leaded MG head which has had the combustion chambers cleaned a little but not much material has been removed, though it does require a skim. Camshaft is an SW5-07, ignition will be Megajolt.
Compression ratio is undecided at the moment. Swift tune recommended a little over 10:1 for their camshaft and the MG engine was originally 10.4:1 but other sources tell me 10:1 will be a struggle with regular pump fuel. I don't want to build an engine that's permanently on the verge of self destruction and/or requires octane boosters, I just want an engine that will be reliable and economical and will last for 10,000s of miles.
Minispares have these clicky and the price looks good but the compression ratio is typically 8.8:1.
So (I think) my questions are:
How do I choose a piston without building it into a block and measuring crown to deck height?
What compression ratio should I be trying to achieve and if I ended up with 8.8:1 will this loose me a lot of power and economy?
If I was to aim for something like 9.5:1 and bought the 21251 pistons at Minispares will a head skim of a mm or so bring compression to around 9.5:1?
Any advice and experience would be greatly appreciated.
