Cobra Monaco With Standard Seatbelt
1 reply to this topic
#1 JakeJakeJake
JakeJakeJake
  • 836 posts
Posted 26 April 2010 - 01:34 PM
Is it possible to use a cobra monaco with a standard seatbelt.
Should I just use it normally or should I unbolt the belt and have it go through the right (when your sitting in it (drivers one)) "hole" where the lap belt of a harness would go?
#2 steverose
steverose
  • 229 posts
Posted 26 April 2010 - 07:56 PM
I can see a few problems trying to use normal belts, although thats not to say it cant be done. The main problem that I would see is that the sides of the seat are high and the belts wont fit through both sides so you will always have a bad fitting seat belt. Could you not fit a 4 point harness?
