Track Rod Ends
11 replies to this topic
#1 dave-r5
dave-r5
  • 317 posts
Posted 27 April 2010 - 09:33 PM
easy
what track rod ends should i be using with adjustable tie rods an 1.5- lower arms
#2 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 27 April 2010 - 09:47 PM
normal track rods ends will do :-
Edited by rick.spi, 27 April 2010 - 09:47 PM.
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 28 April 2010 - 07:21 AM
It would be advisable to use the extended ones with the extra -ve camber.
#4 dave-r5
dave-r5
  • 317 posts
Posted 30 April 2010 - 05:23 PM
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
i wish people would read this, i have now just wasted my time and money buying std rod ends.
#5 Ipod
Ipod
  • 2,024 posts
Posted 30 April 2010 - 05:25 PM
bummer, (and I agree with you totaly)
But it is a forum, and any tom *willy* or harry can give out duff advise..
#6 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 30 April 2010 - 06:33 PM
triumph spitfire track rod ends
#7 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 30 April 2010 - 06:50 PM
x2. Consistently found "extended" mini ones completely useless.
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 April 2010 - 07:10 PM
You certainly MUST use longer TREs with negative arms. We used to just weld a nut onto the Mini one- but Spitfire ones are ideal.
#9 rick.spi
rick.spi
  • 1,686 posts
Posted 01 May 2010 - 10:23 PM
i had the standard ones on mine and they where fine...
#10 HARBER07
HARBER07
  • 4,498 posts
Posted 01 May 2010 - 10:27 PM
Don't mean they were right though...
#11 rick.spi
rick.spi
  • 1,686 posts
Posted 01 May 2010 - 10:30 PM
fair enough, didnt have any problems for over a year of driving tho.
#12 miniobsessed
miniobsessed
  • 211 posts
Posted 02 May 2010 - 11:34 AM
Standard type track rod ends may be trouble free for the entire life of the car... Until the day you hit a decent size bump and the few threads holding your steering together pull straight out = new pair of underpants (even if they are the ones they put you in for your funeral).
Wheather you fit standard ends or 'extended' ends you need to make sure there is sufficient thread engagement (usually this means having engagement at least equal to the diametre or the thread). The biggest problem is not having the steering dead centre when adjusting tracking as this will lead to one track rod end having less thread engagement. And remember, just because the steering wheel is in the 'centre' position doesn't always mean the steering rack is centred.
