Adding A Smith Gauge
Posted 29 April 2010 - 06:39 PM
Can I connect the gauge to the same temp sensor on the block as well as the original dash gauge? or will this cause them both to read wrong?
Also where is the best place to connect to the voltage regulator?
Posted 29 April 2010 - 07:46 PM
Posted 29 April 2010 - 08:11 PM
Edit:
Do I need to get a Voltage Stabilizer like this one? How many gauges can I run off the 1 Stabilizer?
Edited by Brams96, 29 April 2010 - 08:35 PM.
Posted 29 April 2010 - 09:31 PM
If i keep the original dash gauge with the original probe, where is the best place to add a new probe in for water temp?
Or should I disconnect the original gauge and use the new smith gauge? If so, can I just disconnect the wire from the back of the gauge and connect it to the new gauge?
Edited by Brams96, 29 April 2010 - 09:35 PM.
Posted 30 April 2010 - 07:08 PM
Posted 30 April 2010 - 11:17 PM
Edited by jonny d, 30 April 2010 - 11:20 PM.
Posted 01 May 2010 - 01:29 AM
Regardless, the stabilizer you posted the link to will work but it is AWFUL darn expensive. Consider this type as an alternative:
http://cgi.ebay.co.u...=item414f19b284
(eBay item 280499958404 , 12 GBP delivered)
Posted 01 May 2010 - 05:41 PM
Jonny d - The picture you posted in the thread about your fan explosion shows an aluminium box plumbed into the top rad hose, what is this for? Could I do something similar for the water temp?
Cheers for the replies.
Posted 03 May 2010 - 06:15 PM
I took the dash console off but couldn't see any voltage stabilizer so guessed it must be integral to the unit. Plus if it can only run 2 gauges then the fuel and temp gauges already in are those. I'll install the new stabiliser with new water temp and oil pressure gauges so it should all work ok then.
Can I use the oil pressure sensor already in the block or at least use a new sensor in that position? If not where can I plumb it into?
Posted 04 May 2010 - 12:01 AM
Most Smiths oil pressure gauges I have seen are mechanical (apart from those used on some mid- to late-1970s MGBs). Are you sure the one you purchased is electrical and needs the stabilizer? Are you sure the stock one on your Mini is electrical? Regardless, do not plan on running two electrical gauges off of one sending unit. This is exactly the same issue as your initial question about running two temperature gauges off one sending unit. It won't work.
To run two oil pressure gauges use a "T" adapter on the block so you can run the two gauges separately regardless of whether they are electrical or mechanical... or if you want to run the gauge and a low pressure warning light.
Posted 04 May 2010 - 10:17 PM
The original 3 clock dash has a oil pressure warning light not a pressure gauge. I want to run a new pressure gauge and wondered if I can use the sensor that triggers the light to input to the gauge? I take it that I have to swap the pressure switch currently in the block to a different pressure sensor? Is THIS the kind of sender I need? I did come accross another thread about using an adapter do you know anything about these?
The gauge is deffinitely electrical (LINKY) or so the guy says.
Posted 05 May 2010 - 12:41 AM
You cannot use the existing "sending unit" for the light with your new gauge. The part installed on your car at the moment (for the light) is just a pressure switch. It is either on, or off. Your electric gauge expects a variable resistance so it can operate through a range.
The adapter is a pipe "T". I'm sure if you visit the Mini Spares web site and search through their gauge section looking for "adapters" you will find one suitable to allow use of both the switch and the pressure sending unit.
Posted 09 May 2010 - 07:54 AM
Posted 09 May 2010 - 03:23 PM
