Repeaters And Arches
4 replies to this topic
#1 fayjo56
fayjo56
  • 37 posts
Posted 02 May 2010 - 10:51 AM
Planning ahead, I have a '91. Do I legally have to retain the side indicator repeaters on the wing? On standard steel wheels do I have to have arches? It was originaly fitted with standard plastic arches, but the wheels dont seem to stick out much at all.
#2 Ethel
  • 26,581 posts
Posted 02 May 2010 - 10:54 AM
It's a Mini, anything the tight wads at Rover bolted to it in the factory is likely to be essential :D
Side repeaters are required if they were original eqpt, but you could move or swap them as long as they meet the relevant regulation. The tread of the tyres shouldn't be visible when viewed from above, if you can achieve that without arches.
#3 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 02 May 2010 - 11:11 AM
You definitely need the side repeaters for the MOT. They became compulsory in the mid 1980's.
#4 MiniMan65
MiniMan65
  • 152 posts
  • Local Club: Not yet!
Posted 02 May 2010 - 01:39 PM
The side indicators are a must.
As for the arches it comes down to what wheels you are running, if they are standard sized steels then I've always thought no arches was fine as none of the tyre sticks out, anything bigger and you can see the tyre and you need an arch.
#5 fayjo56
fayjo56
  • 37 posts
Posted 04 May 2010 - 05:21 AM
Ta!
