Pitted Exhaust Valves
3 replies to this topic
#1 cap'n crunch
cap'n crunch
  • 1,060 posts
  • Local Club: .
Posted 02 May 2010 - 05:28 PM
I ran a 12G295 (with standard vavle seats not hardened) for about 13-15k miles, checked the head today and all of the exhaust valves and the valve seats in the cylinder head were pitted. Is this a surefire sign of unleaded petrol so i need to get hardend seats? or is there something else happening?
#2 jonny d
jonny d
  • 1,148 posts
Posted 02 May 2010 - 05:40 PM
didn't you use an additive for unleaded fuel?
#3 Davethepioneer
Davethepioneer
  • 944 posts
  • Local Club: S.U.N.M.C
Posted 02 May 2010 - 05:43 PM
this sounds like valve seat recession you could take the head to a specialist and have hardend seats put in so you can run it properly on unleaded or dependant on how bad it is run an additive in your fuel but if there severly pitted then you may need new valves also, so it might be best and cheaper to go for an exchange head with new valves.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 May 2010 - 07:03 PM
'Pitting' is not down to recession - when that happens you actually get very good smooth seats - but the gaps close up! Had your gaps closed at all ? I would grind them in - you may need new valves - and set the exhaust gaps to 15 thou.
