thanks wayne
Edited by fabdabcab, 02 May 2010 - 07:13 PM.
Posted 02 May 2010 - 06:22 PM
Posted 02 May 2010 - 06:27 PM
Posted 02 May 2010 - 06:34 PM
Posted 02 May 2010 - 06:36 PM
Edited by samsernie, 02 May 2010 - 06:39 PM.
Posted 02 May 2010 - 06:42 PM
Edited by wile e coyote, 02 May 2010 - 06:42 PM.
Posted 02 May 2010 - 06:47 PM
no fraid minis not my house i am learning about them the hard way ha ha im a ford mad im doing this up for my wife. not shure where the rest of the arm is think it may have dropped to sump so will have to take that off and check before trying to get her startedIt would have to be new as SPI's use electric pumps. If You're happy there's no debris waiting to chew the engine just rig up a gravity feed to the carb from a small container of petrol on the roof (Mini's not your house!)
Posted 02 May 2010 - 06:51 PM
is there a spacer between the block? is it still spi or carbed? mines running a spi block with twin carbs, fueled by a facet solid state electric pump. if you go for a leccy one youll need to fit a blapump and the blanking plate to the block, i made one for mine out of polished alluminumis
Posted 02 May 2010 - 06:52 PM
Posted 02 May 2010 - 06:53 PM
bugger guess that is the reason no spacer = broken pump and possibly a metal arm floating around the sump oh f-ing joy grrrrrrrrHaven't seem the pump arm break off before but I guess with a cheapo aftermarket pump anything is possible - one though strikes though - there is a spacer block fitted between engine and pump isn't there?? If estemmed ex owner had forgotten that - an spi lump wouldn't have one then damage - or lack of working is bound to have happened....
(damn beaten to it!)
Posted 02 May 2010 - 07:04 PM
Posted 02 May 2010 - 07:11 PM
yeah that is half the problem of buying a project as im sure most people would agree and that is sorting out the bloody bodge jobs in the first place i was going to pull the engine but wanted to hear it run so that i didnt waist any time or money on it and put it back in to find its a donkey. guess im going to have to take the risk now!damn previous owners ehh, i ended up rewiring my mini due to previous owner bodges.. so i know how you feel...
Posted 02 May 2010 - 07:12 PM
Posted 02 May 2010 - 07:46 PM
Posted 02 May 2010 - 09:19 PM
thankyou for that comfirms there was def no spacer fitted we couldnt get the engine to run so hopefully will be fine getting the broken piece out off sump/gearbox on otherhand could prove to be a real headache, i shall try draining the oil and shining a torch through sump plug hole and hope the gods are on my side for once.Looking on the bright side - if the arm came off then the engine wouldn't have run for too long on no fuel supply maybe no damage has ensued...
http://www.somerford...Carburetter.pdf
spacer is No 84.........
