Is zinc primer good for use on bare metal or is red oxide better?
Zinc Primer
Will
, Nov 13 2005 11:26 PM
5 replies to this topic
Posted 13 November 2005 - 11:26 PM
Posted 14 November 2005 - 07:27 AM
zinc primer is for welded seams that cant be reached after welding , generaly not suitable for overpainting (but some are , best to check with the paint manufacturer)
Posted 14 November 2005 - 04:57 PM
So if i was spraying onto bare metal (and some primer) should i use self etch primer?
Posted 14 November 2005 - 06:15 PM
self-etch is not nessesary on steel ,only on aluminium .
Posted 14 November 2005 - 06:22 PM
Ok, now i'm confused :saywhat:
Soooo, if you were me and you had bare metal, what primer would you use?
Sorry if i'm being thick here!
