What's The Best Head Gasket For My 1380?
8 replies to this topic
#1 jordben.00
jordben.00
  • 31 posts
Posted 03 May 2010 - 07:21 AM
i have a copper head gasket but I have never used them before and am unsure if it's suitable for my 1380? or should I stick to a Normal 1?
Thanks :thumbsup:
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 03 May 2010 - 07:24 AM
Lots say Payen BK450 is very good
#3 j-b_2009
j-b_2009
  • 164 posts
Posted 03 May 2010 - 07:29 AM
Edited by j-b_2009, 03 May 2010 - 02:57 PM.
#4 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 03 May 2010 - 07:47 AM
You use sealant on a head gasket? That's against popular advice I'm afraid...
#5 miniobsessed
miniobsessed
  • 211 posts
Posted 03 May 2010 - 08:01 AM
I'm with Ouster... Wouldn't use sealant on a head gasket. Especially as it will squish out everywhere when you torque the head down into your cylinders, water gallery holes and oil gallery.
KC has an article on head gasket issues with 1380 motors... He said the biggest problem is the inconsistency of the bore spacing due to 'factory tolerance'. It is very important to ensure your machine shop 're-centres' the bores to suit your head gasket if you are boring to 73/73.5/74mm (1360, 1380 or 1400cc).
With all that sorted... Just use a good head gasket and make sure both the faces (head and block) are clean enough to eat off and are dead flat.
My 2 cents... (which is about 1.2p at the current exchange rate :thumbsup: )
#6 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 03 May 2010 - 09:32 AM
BK 450 or AF 470 are my choice
#7 MRA
MRA
  • 7,607 posts
Posted 03 May 2010 - 12:00 PM
BK450 everytime :thumbsup:
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 03 May 2010 - 09:18 PM
A little tip smear Hylomar blue between bores and then use a 50mm long piece of 5amp fuse wire and place it on hhlomar then new gasket then head and torque head up to required ...........stops inter bore blow...........it works .....I'v never had a gasket blow since I was tought this by an engineer............... :thumbsup:
#9 samsfern
samsfern
  • 5,243 posts
Posted 03 May 2010 - 09:20 PM
i never use any sealent on headgaskets, never will do either. payen bk450 are the ones to go for!
