battery power
Posted 14 November 2005 - 05:32 PM
My dad spoke to someone at work who said that minis were renowed for having problems with the alternator if they have subs in them.
Is this true? and what do you do to prevent it?
Posted 14 November 2005 - 06:37 PM
A standard Mini alternator (I think) is rated at a max. load of 27A. That is usually just about to run the car and a standard or 'sensible' sound system. If you're going to go crazy and fit just about every bit of ice in your Mini, an uprated alternator is probably a good idea, although this takes a few BHP out of your engine.
I have no idea of figures since I've never meatured my Mini (I don't have I.C.E fitted yet). I was however advised that I can run a pretty simple set up (2 speakers, and a sub) with amp on the existing alternator. Of course, I wouldn't count primarily on this information - you need to do the maths. See what your amp is going to pull.. that's the main part. Also the sorts of amps that the headunit will pull.
Posted 14 November 2005 - 07:08 PM
Posted 14 November 2005 - 07:28 PM
Most minis have the 17acr as this is stated as the replacement and very few older minis have the original on, this is rated at 35amps and should be okay for most applications.
The MG metro type alternator was rated at 55amps i believe.
I've ordered an XR3i alternator (75amp) off ebay, its not a straight fit but with a relatively simple adjustment to the casing should go straight on, i'll be doing a guide on it once i've got it, watch this space for a link.
Posted 14 November 2005 - 07:40 PM
There are also the Lucas A115/45amp, Lucas A127/45amp, Lucas A127/55amp and the Lucas A133/55amp
Posted 14 November 2005 - 09:38 PM
Posted 14 November 2005 - 10:30 PM
How about a J reg escort?
Posted 15 November 2005 - 12:31 AM
Just have at it to see if it looks vaugly like yours to be sure though :wink:
Posted 15 November 2005 - 09:08 AM
Posted 15 November 2005 - 09:28 AM
I am going to have to upgrade the alternator me thinks!
Posted 16 November 2005 - 12:59 AM
Find a battery that will physically fit in the battery tray (you'll be suprised how much extra space there is!) and then just get the battery with the biggest Ah rating
standard mini battery is something like 25Ah - I fitted a 140ah one into my old mini! (severre starting problems)
Posted 16 November 2005 - 10:55 AM
My alternator is standard. As is my battery.
I have no problems.
Posted 16 November 2005 - 03:54 PM
Posted 17 November 2005 - 11:11 AM
Yea, as you saw last night! :tongue:
Oh.
I think its Neil who needs the uprated alternator, Not us!
He still didnt get that thing started in the end.
<|Ben|>
