Converting Drums Brakes To Twin Leading Shoe
Posted 09 May 2010 - 05:27 PM
As some of you know, I am restoring my 1960 mini. It orginally had single leading shoe front brake drums.
I want to upgrade it to twin leading shoe drum brakes. I already have the rear brake backplate assemblies which include the larger diameter wheel cylinders.
I have the standard master cylinder and MK1 brake regulator.
Is there anything else i need to consider when doing this conversion tom the front drum brakes, or is it as straigtforward as just fitting and adding a bridge pipe between the two slave cylinders?
Posted 09 May 2010 - 10:31 PM
Anyone, please?!Hi
Posted 09 May 2010 - 11:26 PM
the brake linnings for the front twin cylinder are wider so you will need them aswell
