Engine Lifting Brackets
8 replies to this topic
#1 mintyminis
mintyminis
  • 79 posts
Posted 09 May 2010 - 08:16 PM
hi ..i just brought a couple of engine lifting brackets..i was told you can bolt them onto the rocker cover with the cover in place..it seems to me that if i do it up tight it squashing the cover down or am i meant to just nip it up a little bit?..anyone knows the best way to use these brackets?...thanks
#2 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 09 May 2010 - 08:19 PM
Pretty sure they are not supposed to be used on the rocker cover bolts?
The only ones I know of are used once the head is off then you slot them on a couple of the head bolts coming out of the block and put the nuts back on.
Edited by Sleepy Stu, 09 May 2010 - 08:20 PM.
#3 jameswhiles
jameswhiles
  • 309 posts
  • Local Club: A5 Minis
Posted 09 May 2010 - 08:27 PM
As far as I know they are meant to bolt on with the rocker cover, some other cars that had an A series engine but with more room in the engine bay had them fitted when they came out the factory
#4 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 09 May 2010 - 08:33 PM
Oh yeah know I now what you mean they look like an L shape!
Edited by Sleepy Stu, 09 May 2010 - 08:33 PM.
#5 mintyminis
mintyminis
  • 79 posts
Posted 09 May 2010 - 08:38 PM
that right it is an L shape..would you think that is ok to lift from the rocker cover?
#6 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 09 May 2010 - 09:00 PM
Yes just use the rocker cover bolts and just give them a nip up with the spanner.
I have done 3 engine out and back in with mine and no problems. I used a steel bar between the two brackets to spread the load, but some people make up some angle iron with hooks on.
#7 mintyminis
mintyminis
  • 79 posts
Posted 11 May 2010 - 07:35 PM
ok.. thanks for your reply..
#8 MR MOL
MR MOL
  • 17 posts
Posted 11 May 2010 - 11:02 PM
hi ive used them numeres times on the rocker cover bolts and theve allways been fine you can get another engine lift that is a big bracket and actually tilts the engine so the diff will come past the subframe and that bolts on the same place
#9 Cooperman
  • 23,329 posts
Posted 12 May 2010 - 11:49 AM
I always use one 'L'-shaped bracket (I all it my 'skyhook') which bolts onto the centre front head stud. It tilts the whole engine the correct amount and it's a 3/8" dia stud, so it's plenty strong enough.
Incidentally, if you bend the 'L' open a bit, you can turn the braket around, use a 3/8" UNC bolt and then the block is held virtually horizontal in both diretions when lowering it back onto the gearbox, making it a one-man job to fit engine to box. In fact I did just that in a few minutes yesterday afternoon.
