Aux Battery
Posted 12 May 2010 - 09:37 PM
im thinking about fitting another battery to Vini as well as the standard one.
i was thinking about fitting a 12v motorbike.
the reason im thinking this is that i wont 7 extra spot/fog lights (dont ask why i just do lol) and also i like my music so am hainv a larger than normal sound system so i dont wont any of it affecting the running of the car, also would mean i could listen to music etc with out draining the main battery
can anyone think of anyreason why i cant/shouldnt do it and also how would i wire it all up so that it charges and works all the time etc
cheers
YetI
Posted 12 May 2010 - 09:40 PM
Posted 12 May 2010 - 09:41 PM
Posted 12 May 2010 - 09:48 PM
If you simply wire it in parallel with the car battery, you'll end up with a whole raft of electrical issues.
I have big Cibies on my car and a Transit battery - it just fits in the battery box
Posted 12 May 2010 - 09:49 PM
roofless asked this question a few days ago
Posted 12 May 2010 - 09:51 PM
oooh so is there a topic on the split charge thingy??
cheers guys
YetI
Posted 12 May 2010 - 09:56 PM
Posted 12 May 2010 - 09:59 PM
why would it run flat if its being charged etc via the alt like the main battery
Posted 12 May 2010 - 10:04 PM
Because of this, the current draw of your car + accessories would come from the smaller battery (the 'bike one) then the draw would be from the car's main battery. However due to the smaller battery now being flat, the current draw would now be through that as a primary means to earth (effectively trying to re-charge) BUT due to the load the car presents................ well without working out a whole load of things, lets just say it's not a good idea.
A car battery is usually rated at something like 40 ampere hours or so (you could draw 1 amp for 40 hours) a motorcycle battery is only about 5 - 10 ampere hours.
Split charge systems usually work with two batteries of approxiamately the same size (powerwise) and alternate the charge as each battery requires.
It would be far easier to have one big battery (generally cheaper too as a decentt split charge system can cost £50 + ) and a decent size alternator which some cars already have.
Emma
Posted 12 May 2010 - 10:06 PM
It will run flat when you stop - with the 'music'
still on! If you are going to keep the engine running - don't worry about an extra battery!!
oh i understnad now lol
Edited by yeti21586, 12 May 2010 - 10:07 PM.
Posted 13 May 2010 - 07:28 PM
When you switch off the ignition the relay switches off any connection between both batteries , so thet the second one can't draw current from the main one.
There are various types of system available-just google "split charge relay" to see what suits you (and your pocket).
just found this:
http://www.landyzone...stem-61268.html
plenty of info there
Edited by mgb1978, 13 May 2010 - 07:31 PM.
Posted 13 May 2010 - 08:22 PM
Also you can get a high amp-hour battery which will help some as well, but the key to it is the alternator.
Posted 13 May 2010 - 09:22 PM
YetI
