Most Effiecent Way To 120hp?
29 replies to this topic
#1 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 13 May 2010 - 06:03 PM
currently have a standard 998, and looking forward to getting my hands on a bigger engine, and having it as a project to work on while my 998 is still in the car
using a 1275 engine, what would be the most cost effective and reliable way of getting 120hp out of an a-series engine?
really looking towards t2 turbo-ing using a mirage manifold, although thats not technically cheap, but neither is trying to get the same amount of power from an n/a with reliability
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 May 2010 - 06:07 PM
Quickest and probably the easiest and most reliable, whack a supercharger on a standard 1275 with a little bit of mods to the head to decrease the compression ratio...
#3 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 13 May 2010 - 06:10 PM
120hp won't have the best driveability N/A, unless you move away from the 5 port head.
A turbo will give the engine the power you want, but as you mentioned is not cheap. Will retain drivability though.
Either way, with 120hp your going to have to invest in drivetrain aswell as the engine.
Not going to be cheap.
#4 Carlzilla
Carlzilla
  • 1,907 posts
not much of a fan of the charger due to the effiency of them, would i be able to get away with head work, or a stage head when going turbo?
plus, would a t2 or t3 be the better option, as ive heard t2s are quite hard to get hold of...
forgot to mention, my car isnt as such a daily driver, i dont really have the need for a car with the job i have at the minute, but id be bored without my mini :-
i know id have to strengthen the diff from reading other things, anything needing to be done to drivetrain?
Edited by Carlzilla, 13 May 2010 - 06:13 PM.
#5 James182
James182
  • 433 posts
Posted 13 May 2010 - 06:11 PM
7/8 port head? ive heard of the 8 port med heads going to 140?
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 May 2010 - 06:20 PM
Well my 1330 was pushing 85 at the wheels, which must be 100 and something at the fly, and apart from high compression and a 296 scatter cam, it's pretty much a standard 1300 GT A series engine engine, if I could be arsed to strap a weber to it and a better flowing head and mappable ignition I could probably get it nearer 100 at the wheels, but it's more a matter of diminishing returns for money spent, plenty of grin factor available as it was...
#7 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 13 May 2010 - 07:52 PM
i would get a cross pin diff and some straigh cut drops for that amount of power, better to be safe than sorry. :-
#8 Cooperman
  • 23,294 posts
Posted 13 May 2010 - 08:09 PM
It's a bit more complicated than that really. If you go forced-induction you need the right bits to make it as reliable as possible. the weak link is and will always be the transmission. With, say, 120 bhp you do need the improved drive shafts, a cross-pin diff and a gearbox in really good condition. I would not go to SC drops as they are simply too noisy for the road and helicals are OK anyway. It's normally the diff, shafts and CV joints which fail with ultra-high power output.
If you go normally aspirated, to get 120 bhp you will have, effectively, a full race engine. This will need a lower final drive to keep it 'on-the-cam' as you'll be using a 296 or equivalent cam with nothing much below 3000 rpm. This will mean a loss of top speed as the diff ratio will also need to be lower and a close-ratio box to ensure that when you change up you'll still be in the muh narrower power band. My Cooper 'S' is NA with twin H4's and it gives 115 bhp at 6400 rpm. It is very 'cammy' and I run a 3.9 FD ratio with a SC box, but it's a rally car with 0 - 60 in 7.4 ses. However, at 6000 rpm it only pulling about 85 mph in top. To pull the sort of revs where the engine will give the power will mean serious engine preparation such as centre main strap, full balance, lightened components, top quality pistons, etc.
#9 Pauly
Pauly
  • 4,213 posts
Posted 13 May 2010 - 08:15 PM
You can build a nice turbo engine for probably the same price as a n/a engine making the same power, if you dont want loads of hp then 120hp is quite a nice figure for turbo power, you wont need much boost pressure and will be just as relaible as n/a.
#10 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 13 May 2010 - 08:36 PM
BUY MY CAR!!!!!!!!!!!!!!!!!
#11 rick.spi
rick.spi
  • 1,686 posts
Posted 13 May 2010 - 08:43 PM
drive shafts shouldnt be a problem?
alot of the very high power turbo minis have normal driveshafts, so a 120bhp engine whould be fine. my engine will be tuned to 140bhp with boost for now and ive still got the standard driveshafts.
#12 Pauly
Pauly
  • 4,213 posts
Posted 13 May 2010 - 09:13 PM
Standard shafts are more than up to the job.
#13 rick.spi
rick.spi
  • 1,686 posts
Posted 13 May 2010 - 09:29 PM
exactly what i thought.
a good condition standard box, some sc drops and a cross pin diff will be good at 120 bhp, thats not too far off what ive got with 140, but the amount of torque your engine has will affect how long a transmission will last. :)
Edited by rick.spi, 13 May 2010 - 09:30 PM.
#14 Carlzilla
Carlzilla
  • 1,907 posts
Posted 14 May 2010 - 02:43 PM
sounds good to me, i want something proper nippy, but nothing ott so 120hp was nice round figure in my head, so im glad thats achieveable without going silly :bah:
#15 rick.spi
rick.spi
  • 1,686 posts
Posted 14 May 2010 - 03:32 PM
120 should be more than nippy. i would class a well setup standard 1275 as "nippy" lol :bah:
Edited by rick.spi, 14 May 2010 - 03:33 PM.
