Can I Use Bike Rear Shocks On The Front Of My Car?
4 replies to this topic
#1 plunger
plunger
  • 16 posts
Posted 17 May 2010 - 04:32 AM
just wondering if anyone has used bike shocks on a mini. Im thinking about using a r1 rear shock on each front side. There 11 1/2 - 12" long, so there roughly the same length as a standard strut. They also has a resivour attached to them stock. Reason im asking, a stock cone will run me 100cdn, where i can get a used r1 shock for around 30-40$ off ebay. :dontgetit:
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 May 2010 - 06:17 AM
i don't think you will find anyone that has tried this
the only way to know would be to buy some and see what the ride is like
#3 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 17 May 2010 - 06:37 AM
Half of me is saying give it a go, but the sensible half of my head is screaming that it will never work.
While the shock might physically fit, it will be set up for a machine that is only 180-200kgs in weight and has rising rate linkage between the swingarm and the shock. The chances of the spring rate (stiffness) or the damping being suited for a Mini are slim to nonexistent, but you never know unless you try..........
#4 plunger
plunger
  • 16 posts
Posted 17 May 2010 - 07:28 AM
found some specs for a r1 rear shock,
Travel: 6 cm realistic, 7 cm without bump stop
Spring rate: 9 kg/mm or around 500 lbs/in
Pre-load adjustable: 1 cm
Compression and Rebound independently adjustable.
Designed to be mounted upside down (better for unsprung mass.)
Weight: around 6 lbs
Size: eye to eye: 30 cm
Ends: damper end: solid 1cm hole. Spring end: 1 cm needle bearing.
you have to remember, a bike also has to support a driver. So you have a 250kg bike and a 80-100kg pilot per 1 shock. I might just try it
#5 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 17 May 2010 - 07:58 AM
i actually did this a few years ago, but with shocks from a scrambler, i never drove it on the road, as i was only 15 at the time, but the shocks made the front very stiff, not sure if it would be a good thing, but definatly `1 to experiment with!
