Hi Guy's,
I am building a 1380 twin cam with conversion components from specialists components.
So far I am thinking along the lines of pre A+ block (A+ are rare in NZ) with swifttune steel caps and studs. Probably SC crank and rods. We are using a 16 valve RS head.
I am planning on using helical drop gears and a A+ gearbox.
Any tips or ideas will be appreciated. I have replaced all the oil gallery bungs with either 1/8" or 3/8" npt allen head plugs.
Clubman
1978
Not so much problems more decisions decisions.
Cheers,
Craig.
Bmw Twin Cam A Series 1380
Raven coll
, May 17 2010 10:41 AM
1 reply to this topic
Posted 17 May 2010 - 10:41 AM
Posted 17 May 2010 - 01:35 PM
When I was looking into the BMW K conversion I found the most info on EFi Mini forum. I can't help you myself as I bottled it and ended up buiding a conventional 1380. http://www.efiminis....l.com/index.php
