Mk1 Flasher Wiring
3 replies to this topic
#1 wesson124
wesson124
  • 150 posts
Posted 17 May 2010 - 05:54 PM
hi guys, I hav a mk1 and I am trying to wire in the flasher, however I dont want to wreck it, does anyone know which wires go to which terminals?
many thanks in advance
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 17 May 2010 - 10:18 PM
It does not matter wich way you do the connections as it works either way............. :dontgetit:
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 May 2010 - 10:44 PM
The Mk1 has a 3-prong flasher and one output is dedicated to the warning light while the other two are "in" and "out".
The picture in the link below is for an aftermarket, electronic flasher connected to the Mini's wiring.
http://home.mindspri...rketFlasher.jpg
The wiring diagrams show the following connections for a standard Lucas flasher:
light-green/brown = L terminal (to turn signal switch)
light-green/purple = P terminal (indicator lamp)
green = B terminal (from battery/fuse)
#4 tommy13
tommy13
  • 878 posts
Posted 18 May 2010 - 06:22 PM
There is a link here to Vehicle Wiring Products page which gives a terminal identification cross reference to many common flasher units available in the UK.
It is interesting to note that the electronic unit shown in D K Lawsons link has the same terminal identification letters as the electro mechanical unit in the wiring products catalogue.
If you use an electronic unit from Wiring Products you would need a RFL5 and an additional earth wire on to terminal 31.
http://www.vehicle-w...ys/flashers.php
