Hottest Spark Plug In A Mini
8 replies to this topic
#1 Mei
Mei
  • 74 posts
Posted 17 May 2010 - 09:05 PM
right just wondering what the hottest plug i can safely run on 8.5 compression ratio 1100....
cheers guys.
#2 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 17 May 2010 - 09:44 PM
Well i know that in the NGK sparkplug world, the lower the number the hotter the plug, so
BP6ES are cooler than BP5ES
if your running BP6ES as a standard mini plug, and want warmer order BP5ES...
but i don't know how much each number means, as in to what degree of heat the number dictates, thats quite a low Compression ration unit there so would imagine you can run a hotter plug than alot of people.
any reason why you want to do this?
#3 Mei
Mei
  • 74 posts
Posted 17 May 2010 - 09:47 PM
I'm burning oil badly, well not burning its wetting my plugs causing them to stop firing....so an old trick i know is to increase the heat of the plug to stop this from happening.
I'm currently using BP5ES
#4 liirge
liirge
  • 4,097 posts
Posted 17 May 2010 - 09:49 PM
Yeah i know of that little trick as well i believe someone on here is using non standard mini plugs to deal with his weber fuelling issues.. but i just can't remember who.
#5 Wil_h
Wil_h
  • 3,244 posts
Posted 17 May 2010 - 10:10 PM
Can you even buy cooler plugs than 5s?
I would safely say you could run any plug of the right size with no chance of danaging anything other than the plug.
#6 liirge
liirge
  • 4,097 posts
Posted 17 May 2010 - 10:13 PM
Will, Any plug number above 5 is cooler...so 6's 7's 8's are cooler plugs.
I believe you can get as hot as BP2ES.
#7 MRA
MRA
  • 7,607 posts
Posted 18 May 2010 - 10:10 AM
BP2ES are available......... not sure what application though ?
#8 Wil_h
Wil_h
  • 3,244 posts
Posted 18 May 2010 - 11:58 AM
Always confuese me, but interesting that 2s are available, but not from halfords I'm sure
#9 Ethel
  • 26,073 posts
Posted 18 May 2010 - 12:43 PM
You're talking about 2 things hotter engine - cooler plug, hence the amguity. Electronic ignition and wider plug gaps might help as well.
