1275 Standard With Weber 45
5 replies to this topic
#1 benharris001
benharris001
    Starting My Mini Up
  • 4 posts
Posted 19 May 2010 - 01:04 PM
hi there
i have inherited a weber 45 with manifold from a mate. i am going to fit it to my standard 1275 mini. although the weber does need a recon. any idea how hard this is. and if it would make a difference to the pover of the car
many thanks
Edited by benharris001, 19 May 2010 - 02:48 PM.
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 19 May 2010 - 01:25 PM
IMO Stick with the HIF 44 and referb it. It will supply more than enough for your engine
#3 Cooperman
  • 23,326 posts
Posted 19 May 2010 - 05:02 PM
There is no point improving the induction system unless the rest of the engine can benefit, which a standard engine just won't. You wiould need a better cam, a gas-flowed head and a better exhaust system to see any improvement when fitting a Weber. Don't forget, you have to cut the bulkhead away and weld in a box to clear the Weber intakes. It's quite a major job, but you could do a lot of engine work whilst the engine is out as it probably will be to fit the weber bulkhead box..
#4 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 19 May 2010 - 05:06 PM
and because your cutting the bulk head you would need an IVA, which will then mean that loads more of mods will be needed to pass!
#5 Cooperman
  • 23,326 posts
Posted 19 May 2010 - 06:09 PM
I've never tried, but it may be possible to use the existing hole in the bulkhead and make up an aluminium box to bolt onto the bulkhead on the inside with a suitable sealant. That way you are not modifying the bulkhead, whih remains as original. The box is just to fireproof the interior and to provide a new mounting for the central instrument binnacle, if a central binnacle is fitted. In any case, it would not take a genius to slightly modify the existing bulkhead hole so that it still looks standard. How many MoT testers actually know, for sure, the profile shape and size of that hole. We are only talking about an inch or so. Next time I have a 45DCOE in my hands I'll try it for size. It might mean a special inlet manifold to get it to line up with the hole.
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 19 May 2010 - 08:44 PM
Unless it has a swan neck manifold or your MOT Tester is a proper jobsworth !!!
