Negative Camber
Posted 20 May 2010 - 12:27 PM
ive a 92 spi cooper. i didnt drive it for about 4 months last year and since jan of this year ive changed the tyres twice! once in jan and again about a month ago. the insides are wearing really fast. i can see the wheels have got negative camber on them but ive never put a kit on and havent had this problem in owning the car for 5 years.
i do about 1000 miles a month so surely yokoA539s should last longer than that? ive always used these and they used to last loads longer :S
is there anything i can do or anything that might be wrong that would cause such fast wear?
AND before anyone askes I dont wheelspin out of junctions or anything silly to just waste tyres.
Im really confused....
any helps appreciated!
Joel
Posted 20 May 2010 - 12:41 PM
Edited by 1293sleeper, 20 May 2010 - 12:43 PM.
Posted 20 May 2010 - 12:42 PM
hello all
Joel
Posted 20 May 2010 - 01:39 PM
If it's lowered then that provides some negative camber?
Dave
Posted 20 May 2010 - 03:51 PM
i do have the car mega low, would that cuase the camber? is there anything i can do to remedy this as its probably a good 3 degree camber....
Posted 20 May 2010 - 03:52 PM
How high is the car?
Dave
This man's got it. If your cones have collapsed (if you've never changed them, you can bet they are) then your suspension will be lowered. Mine was the same, so i put hilos on and jacked the suspension up.
Posted 20 May 2010 - 03:56 PM
ive just changed top and bottom ball joints in about feb time so shouldnt be worn?
It sure would mate. Raise it up to something sensible or get adjustable bottom arms to dial out some of the excess neg camber.
Posted 20 May 2010 - 03:57 PM
if you fit adjustable camber brackes you can get it set so its no as bad. which would help your problem.ive just changed top and bottom ball joints in about feb time so shouldnt be worn?
Posted 20 May 2010 - 07:20 PM
Damn I'm good!
Posted 21 May 2010 - 10:01 AM
