Mot Failure
6 replies to this topic
#1 Bano567
Bano567
  • 88 posts
Posted 20 May 2010 - 02:59 PM
Just took my mini clubby estate for a mot and they failed it on emissions and not having a door handle for the back door, i can unlock the door from the inside. is this right? the year is 1979. Thanks alot Joe.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 May 2010 - 03:12 PM
Every car no matter what age has to pass an emissions test of some form, the scale of that test is determined by the age of the vehicle
Vehicles first used on (or after) 1 August 1975 are subject to the standard non-cat emissions test, pre that then it's just a visual smoke test
Regarding the handle on the back door, that's a weird one, Yes the Front Driver and Passenger Doors need to be able to be opened from both the inside and outside, but first time I've heard that rule being applied to a rear door... I'd question that...
Edited by Guess-Works.com, 20 May 2010 - 03:12 PM.
#3 Bano567
Bano567
  • 88 posts
Posted 20 May 2010 - 03:23 PM
well the normal tester comes of holiday tomorrow, he never does a emission test on it, failed on hydrocarbon 1581, max is 1200 how can i get this down? thanks
Edited by Bano567, 20 May 2010 - 03:46 PM.
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 20 May 2010 - 04:05 PM
all doors have to open from inside and outside
dave
#5 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 20 May 2010 - 04:17 PM
You might have to try play with mixture. But realy a decent mot place would have ago for you our place tends to.
My mate who tests mots takes the vac advance pipe off the carb that some times work or he takes breather off.
They have to rev between 2000 and 3000 RPM when doing the Emitions test but we tend to do it btween 2500-3000.
#6 Bano567
Bano567
  • 88 posts
Posted 20 May 2010 - 04:22 PM
well the cars been like it for about ten years, never had any trouble before.
#7 Cooperman
  • 23,328 posts
Posted 20 May 2010 - 04:32 PM
Set the tickover to about 1800 rpm then weaken the carb off so that it will still just run. That normally does the trick.
