White Smoke
2 replies to this topic
#1 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 20 May 2010 - 04:16 PM
Model:Mpi Cooper
Year: 1997
Hi all
I refer to my earlier post
http://www.theminifo...x...=152812&hl=
I was having some issues with the car when driving I was getting a lot of white smoke.
Upshot was the Brake master was leaking into the servo > into the inlet manifold ;)
I have replaced the brake master, cleaned out the servo, replaced new oil, oil filter, ran engine flush throu to clean out the oil and engine, installed a new head gasket and went as far last night as to change back to the standard rover head.
Last night to stipped the stage 3 head off and returned the original rover head, as I thought the valve stem seals were perished.
On the drive home today I was still getting white smoke, occours a lot when cornering. I also can smell a burning of oil when this happens. To top this off I am going throu a lot of oil :D
I am thinnking Piston Rings ???
Your views
Mike
#2 Pauly
Pauly
  • 4,213 posts
Posted 20 May 2010 - 07:37 PM
White smoke indicates steam, could be head gasket failed between water gallery and cylinder, also if your using a lot of oil do you know what the condition of the valve guides and oil seals are like? Failing that its more than likely piston rings, best to do a compression test first to see.
#3 mykweb
mykweb
  • 543 posts
Posted 20 May 2010 - 07:41 PM
I think compression test is my next thing
I am not getting any major water loss but getting oil loss so think its pistons
Mike
